1995 - 1996 Corvette: Service Bulletin: Transmission Fluid Leak From Pump Body
Estimated Reading Time: 2 Minutes Subject: Transmission Fluid Leak From Pump Body (Replace Bushing)
Model and Year:
1995-96 BUICK ROADMASTER
1995-96 CADILLAC FLEETWOOD
1995-96 CHEVROLET CAPRICE, CAMARO, CORVETTE
1995-96 PONTIAC FIREBIRD
1995-96 CHEVROLET AND GMC TRUCK C/K, M/L, S/T, G MODELS
1996 OLDSMOBILE BRAVADA
1995-96 HOLDEN COMMODORE WITH HYDRA-MATIC 4L60-E TRANSMISSION (RPO M30)
Bulletin Number: 57-71-26B
REVISION: 02/06/97
THIS BULLETIN IS BEING REVISED TO CHANGE THE LABOR OPERATION CODE. PLEASE DISCARD CORPORATE BULLETIN NUMBER 57-71-26 (SECTION 7 -- TRANSMISSION). ---------------------------------------------------------------------- REVISION: 04/02/97
THIS BULLETIN IS BEING REVISED TO REMOVE THE WARRANTY STATEMENT UNDER CORRECTION TO GMC DEALERS. PLEASE DISCARD CORPORATE BULLETIN NUMBER 57-71-26A (SECTION 7 -- TRANSMISSION).
CONDITION:
(FIGURE 1) SOME OWNERS MAY EXPERIENCE A PUMP FLUID LEAK. STARTING SEPTEMBER 11, 1995 (JULIAN DATE 254) ALL UNITS ARE BUILT USING A REVISED DESIGN BODY BUSHING.
CAUSE:
THE PUMP BUSHING IS SPINNING OR WALKING OUT OF THE BODY.
CORRECTION:
REPLACE THE PUMP BODY BUSHING USING KENT-MOORE TOOL J41778.
REMOVAL AND REPLACEMENT PROCEDURE (FIGURES 2-5)
1. REMOVE THE FRONT HELIX RETAINER (244). 2. REMOVE THE OIL SEAL ASSEMBLY (243). 3. REMOVE THE PUMP BODY BUSHING (242) USING TOOL J41778-1. 4. INSTALL NEW BUSHING USING J41778-2 AS A POSITIVE STOP AND AN ARBOR PRESS WITH J41778-1.
REFER TO YOUR SERVICE MANUAL FOR PROPER PUMP ASSEMBLY REMOVAL AND REPLACEMENT PROCEDURES.
SERVICE PARTS INFORMATION
PART # DESCRIPTION * 24206030 BUSHING-PUMP BODY
* THIS PART WILL SERVICE ALL 4L60 AND 4L60-E APPLICATIONS FROM 1982-1996.
