1996 Corvette: Service Bulletin: 3 - 2 Part Throttle Downshift Flare
Estimated Reading Time: 2 Minutes Subject: Service Bulletin: 3 - 2 Part Throttle Downshift Flare (Replace 3 - 2 Solenoid)
Model and Year:
1996 BUICK ROADMASTER
1996 CADILLAC FLEETWOOD
1996 CHEVROLET CAMARO, CAPRICE, CORVETTE
1996 PONTIAC FIREBIRD
1996 OLDSMOBILE BRAVADA
1996 CHEVROLET AND GMC C/K, M/L, S/T, G MODELS WITH HYDRA-MATIC 4L60-E (RPO M30)
1996 HOLDEN COMMADORE "VS"
Bulletin Number: 67-71-47
**IMPORTANT: CANADIAN DEALERS SHOULD REPAIR TRANSMISSIONS FOLLOWING ESTABLISHED REPAIR PRACTICES.
CONDITION:
(FIGURES 1 AND 2)
SOME OWNERS OF THE ABOVE MODELS WITH A HYDRA-MATIC 4L60-E TRANSMISSION (BUILT BEFORE MAY 24, 1996/JULIAN DATE 6145) MAY EXPERIENCE AN ENGINE SPEED FLARE OF 1000-2000 RPM, DURING A PART THROTTLE DOWNSHIFT AT 19-31 MPH. THIS CONDITION WILL NOT SET ANY DTC’S (DIAGNOSTIC TROUBLE CODES).
CAUSE:
EXHAUST SEAT ON THE 3-2 CONTROL SOLENOID BACKING OUT.
CORRECTION:
(FIGURE 3)
REPLACE THE 3-2 CONTROL SOLENOID. JULIAN DATE ON THE SOLENOID WILL BE MAY 13, 1996 (6134) OR LATER.
PARTS INFORMATION:
NEW PART NUMBER DESCRIPTION
24209121 SOLENOID, 3-2 CONTROL
PARTS ARE EXPECTED TO BE AVAILABLE ON JULY 1, 1996 FROM GMSPO
FIGURE 1 - HYDRA-MATIC 4L60-E TRANSMISSION IDENTIFICATION INFORMATION FIGURE 2 - HYDRA-MATIC 4L60-E TRANSMISSION IDENTIFICATION INFORMATION FOR TWO-PIECE CASE FIGURE 3 - LOCATION AND IDENTIFICATION OF THE 3-2 CONTROL SOLENOID ON THE CONTROL VALVE BODY
