1996 Corvette: Transmission Diagnostic Trouble Codes
Estimated Reading Time: 1 Minutes1996: Transmission Diagnostic Trouble Codes
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0560 System Voltage
DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0719 Brake Switch Circuit Low Input
DTC P0724 Brake Switch Circuit High Input
DTC P0742 TCC System Stuck On
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0751 1-2 Shift Solenoid Valve Performance
DTC P0753 1-2 Shift Solenoid Circuit Electrical
DTC P0756 2-3 (B) Shift Solenoid Performance
DTC P0758 2-3 (B) Shift Solenoid Electrical
DTC P1572 TCS Active Circuit Low Voltage Too Long
DTC P1810 TFP Valve Position Switch Circuit
DTC P1812 Transmission Fluid Overtemperature
DTC P1860 TCC PWM Solenoid Circuit Electrical
DTC P1864 TCC Solenoid Electrical
DTC P1870 Transmission Component Slipping
DTC P1886 3-2 SS Valve Assembly CKT Electrical
