1997 - 1998 Corvette: Service Bulletin: Belt Rumble Noise at Low Idle Speeds
Estimated Reading Time: 1 MinutesSubject: BELT RUMBLE NOISE AT LOW IDLE SPEEDS (INSTALL ACCESSORY DRIVE BELT TENSIONER/ACCESSORY DRIVE BELT)
Number: 87-61-13
Models: 1997-1998 CHEVROLET CORVETTE WITH 5.7L ENGINE (VIN G - RPO LS1) AND 4L60-E AUTOMATIC TRANSMISSION BUILT PRIOR TO VIN BREAKPOINTS: 1997--109680 1998--100060
Condition
SOME OWNERS MAY COMMENT ON ACCESSORY DRIVE BELT NOISE AT LOW IDLE SPEEDS WITH A/C ON AND P/S AT FULL TURNED LOCKED. CONDITION MAY BE MORE PROMINENT AT HIGH AMBIENT TEMPERATURES AND DURING ENGINE SHUT DOWN.
Correction
INSTALL THE PART NUMBERS LISTED BELOW
Parts Information
DESCRIPTION PART NUMBER
ACCESSORY DRIVE BELT TENSIONER 12559325
ACCESSORY DRIVE BELT 12561501
