1997 - 1998 Corvette: Service Bulletin: Hiss Type Noise Coming From Weatherstrip When Closing Right or Left Door
Estimated Reading Time: 1 Minutes Subject: HISS TYPE NOISE COMING FROM WEATHERSTRIP WHEN CLOSING RIGHT AND/OR LEFT DOOR (ADD RELIEF HOLE)
Number: 83-15-07
Models: 1997-1998 Chevrolet Corvette Coupe and 1998 Chevrolet Corvette Convertible
Condition: SOME CUSTOMERS MAY COMMENT ON A HISS TYPE NOISE COMING FROM THE WEATHERSTRIP WHEN CLOSING THE RIGHT AND/OR LEFT DOOR WITH THE GLASS IN THE FULL UP POSITION.
Correction:
- REMOVE THE WEATHERSTRIP ABOVE THE DOOR GLASS AND CUT AN AIR RELIEF HOLE 3MM WIDE (.12 IN) BY 10MM LONG (.4 IN) IN THE BACK OF THE WEATHERSTRIP.
- RESEAL THE FRONT AND REAR CORNERS ON THE COUPE OR THE FRONT CORNER OF THE CONVERTIBLE WITH WEATHERSTRIP ADHESIVE; 3M(R) P/N 08011, OR EQUIVALENT. SEE FIGURE 1.
- REINSTALL WEATHERSTRIP.
WARRANTY INFORMATION:
FOR VEHICLES REPAIRED UNDER WARRANTY, USE:
LABOR OPERATION LABOR OPERATION NUMBER DESCRIPTION TIME
C1420/C1421 WEATHERSTRIP - ALIGN OR REPLACE 0.3 HR
C1715/C1716 WEATHERSTRIP SIDE RAIL (FRONT) 0.2 HR REPLACE
![](/tech/knowledgebase/images/tech/83-15-07.gif)
