1997 - 1998 Corvette: Service Bulletin: Inoperative Remote Keyless Entry System and/or Tire Pressure Monitor System
Estimated Reading Time: 1 MinutesSubject: INOPERATIVE REMOTE KEYLESS ENTRY (RKE) SYSTEM AND/OR TIRE PRESSURE MONITOR (TPM) SYSTEM (REPLACE RECEIVER)
Number: 83-90-14
Models: 1997-1998 Chevrolet Corvette
CONDITION:
SOME CUSTOMERS MAY COMMENT THAT THE REMOTE KEYLESS ENTRY (RKE) SYSTEM AND/OR THE TIRE PRESSURE MONITOR (TPM) SYSTEM IS INOPERATIVE IN TEMPERATURES BELOW 18 DEGREES CELSIUS (50 DEGREES FAHRENHEIT).
CAUSE:
SOME REMOTE DOOR/REAR COMPARTMENT RECEIVERS WERE BUILT WITH AN INTERNAL COMPONENT THAT MAY BE SUSCEPTIBLE TO COLD TEMPERATURES.
CORRECTION:
INSTALL NEW REMOTE DOOR/REAR COMPARTMENT RECEIVER, FOLLOWING THE PROCEDURE IN THE SERVICE MANUAL.
PARTS INFORMATION:
Part Number: 10422088
Description: RECEIVER, REMOTE DOOR/REAR COMPARTMENT LOCK
