1997 - 1998 Corvette: Service Bulletin: Reduced Engine Power Message Along With Partic. Powertrain
Subject: REDUCED ENG. POW. MESSAGE ALONG W/ PARTIC. PWRTRAIN
Number: 87-65-16
Models: 1997-98 CHEVROLET CORVETTE WITH 5.7L V8 ENGINE (VIN G - RPO LS1)
Condition
CONDITION #1: INTERMITTENT REDUCED ENGINE POWER EVENT, ACCOMPANIED BY P-1516, OR P1518 TROUBLE CODES.
IF A SITUATION ARISES WHERE A P-1516 TROUBLE CODE IS ACCOMPANIED BY A
P-1120 AND/OR P-1220 TROUBLE CODE, THIS SERVICE BULLETIN DOES NOT APPLY. IN THESE CASES THE TECHNICIAN MUST USE THE NORMAL STRATEGY BASED DIAGNOSTIC.
CONDITION #2: INTERMITTENT REDUCED ENGINE POWER ACCOMPANIED BY TROUBLE CODE P-1125 AND ANY OF THE FOLLOWING TROUBLE CODES:
P-1276 P-1281 P-1286
Cause
CONDITION MAY BE DUE TO DIAGNOSTIC SOFTWARE AND CALIBRATION IN THE TAC-MODULE WERE NOT OPTIMALLY UTILIZED.
Correction
IF THE ABOVE CONDITIONS CANNOT BE CORRECTED USING THE NORMAL STRATEGY BASED DIAGNOSTICS LISTED IN THE SERVICE MANUAL, INSTALL THE NEW TAC- MODULE LISTED BELOW.
Parts Information
NEW TAC-MODULE PART # 25319443
