1997 - 1998 Corvette: Service Bulletin: Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative
Estimated Reading Time: 1 MinutesSubject: Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative (Replace RKE Module)
Number: 99-08-52-002 - (04/20/1999)
Models: 1997-98 Chevrolet Corvette
Condition:
Some customers may comment on the following conditions:
- The remote keyless entry system (RKE) is intermittently inoperative.
- The Driver’s Information Center is inoperative or it displays the following messages intermittently and usually at start-up of the vehicle:
- Low tire pressure.
- Tire pressure trouble codes may occur.
Cause:
When the ambient temperature of the interior is less than 10° C (50° F), some oscillating transistors may stop working. However, when the interior warms, they begin to work with the next key cycle. The module in question is P/N 10401040.
Correction:
Replace the RKE Module with P/N 10422621.
Parts Information:
Part Number |
Description |
10422621 |
Module, Keyless Entry & Low Tire Pressure Module |
