1997 - 1999 Corvette: Service Bulletin: Premature Wear of Leather Material on Bucket Seatback Bolster
Subject: Premature Wear of Leather Material on Bucket Seatback Bolster (Replace Cover)
Number: 99-08-50-010
Models: 1997-99 Chevrolet Corvette Built Prior to VIN Breakpoint X5116322
Condition
Some customers may comment that there appears to be premature wear of the leather material on the driver’s or passenger bucket seatback in the bolster area.
Correction
Replace the seatback leather cover with a new cover that has additional felt added to the backside of the leather to increase durability. Also, the leather material in the bolster area has been changed to a more durable vinyl material. For information on replacing the seatback cover, see Service Manual Update Bulletin #99-08-50-002.
Parts Information
Part Number
Description
Color/RPO
Seat Type/RPO
12455509
Cover Asm, Seatback - Driver
Black (193)
Base (AR9)
12455510
Red (943)
Base (AR9)
12455511
Pewter (923)
Base (AR9)
12455512
Light Oak (673)
Base (AR9)
12455521
Black (193)
Sport (AQ9)
12455522
Red (943)
Sport (AQ9)
12455523
Pewter (923)
Sport (AQ9)
12455524
Light Oak (673)
Sport (AQ9)
12455515
Cover Asm, Seatback - Passenger
Black (193)
Base (AR9)
12455516
Red (943)
Base (AR9)
12455517
Pewter (923)
Base (AR9)
12455518
Light Oak (673)
Base (AR9)
124555527
Black (193)
Sport (AQ9)
12455528
Red (943)
Sport (AQ9)
12455529
Pewter (923)
Sport (AQ9)
12455530
Light Oak (673)
Sport (AQ9)
Warranty Information:
Labor Operation
Description
Labor Time
C7050
Cover and/or Pad, Front Seatback Cushion - Left (Driver’s w/Base Seat)
0.3 hr
C7050
Cover and/or Pad, Front Seatback Cushion - Left (Driver’s w/Sport Seat)
0.4 hr
C7051
Cover and/or Pad, Front Seatback Cushion - Right (Passenger w/Base Seat)
0.3 hr
C7051
Cover and/or Pad, Front Seatback Cushion - Right (Passenger w/Sport Seat)
0.4 hr
Policy: S - Additional 0.3 hr if the vehicle is delivered to and from the repair location.
