1997 - 1999 Corvette: Service Bulletin: Squeak Type Noise From Leather Shift Boot when Shifting Gears
Subject: Squeak Type Noise From Leather Shift Boot when Shifting Gears (Replace Leather Shift Boot)
Number: 99-07-29-001
Models: 1997-99 Chevrolet Corvette with Manual Transmission (RPO MM6)
Condition
Some customers may comment that there is a squeak type noise coming from the leather shift boot when the gearshift lever is being moved.
Correction
Install a new leather shift boot assembly, P/N 10433159, using the Shift Control Boot Replacement procedure in the Manual Transmission - MM6 sub-section of the appropriate Service Manual.
Parts Information
Part Number
Description
10433159
Boot, Manual Transmission Shift Control
