1997 - 2002 Corvette: Service Bulletin: Automatic Transmission Service Procedure Changes
Subject: Automatic Transmission Service Procedure Changes
Number:  99-07-30-020A
Models: 2002 and Prior Passenger Cars and Light Duty Trucks with Automatic Transmissions
This bulletin is being revised to add the 2000-2002 model years. Please discard Corporate Bulletin Number 99-07-30-020 (Section 7 -- Transmission).
This bulletin covers the service procedure for cars and light duty trucks equipped with automatic transmissions which are in warranty.
This service procedure allows dealers to repair or replace automatic transmissions based upon the cost of the repair and customer satisfaction. Each repair should be evaluated individually to determine the need for repair or replacement.
  • Transmissions should be repaired whenever the cost of the repair is less than the cost of a Goodwrench Transmission Assembly.
  • A Goodwrench Transmission Assembly should be installed whenever the cost of the repair is greater than an assembly.
  • When two or more repair attempts have not corrected the condition, contact TAC and/or your Area Service Manger (ASM) (DSM in Canada) for further assistance.
  • Only GM Goodwrench DEXRON® III automatic transmission fluid is to be used for any warranty service of automatic transmissions.
Cooler Flushing
Cooler flushing and a flow check MUST be performed whenever a transmission is removed for service. It is essential to flush the cooler prior to installation of a Goodwrench Transmission Assembly or when fluid contamination is suspected. Use Kent-Moore tool J 35944-A and solvent J 35944-22 to flush the cooler. Instructions are published in each Service Manual On-Vehicle Service Section. Refer to Corporate Service Bulletin 99-07-30-017 for further details on transmission cooler flushing and flow check.
Step
Concern
No
Yes
1.
Transmission/Transaxle Concern
Have two or more repair attempts failed to correct condition?
Go to step 2
Contact TAC and / or your ASM (DSM In Canada) for further assistance.
2.
Remove unit
Go to step 3
3.
Dissemble Inspect components
Estimate repair costs
Does cost of the repair Exceed cost of SRTA ?
Go to step 4
Go to step 5
4.
Correct as necessary and overhaul.
Reassemble unit
Go to step 6
5.
Reassemble unit for core return
Go to step 6
6.
Flush cooler
Go to step 7
7.
Reinstall unit (Overhauled or SRTA)
Go to step 8
8.
ROAD TEST
Is transmission / transaxle condition Repaired ?
Go to step 1
Go to step 9
9.
Return vehicle to customer
Warranty Information
Labor operation K7000 (TRANSAXLE ASSEMBLY - replacement) permits add on time to be used as needed for disassemble, inspect and reassemble, when it has been determined the cost of overhaul exceeds cost of replacement. (Steps 3 and 5 above)
Labor Operation K7000 (TRANSAXLE ASSEMBLY - replacement) includes time to perform cooler line flush. (Step 6 above)
