1997 - 2004 Corvette: Resetting the Engine Oil Life Monitor
Estimated Reading Time: < 1 MinuteMethod 1
- Turn the ignition on, but make sure the engine is off.
- Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage.
- Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 99%" will appear on the display.
Method 2
- Turn ignition to on, do not start engine.
- Clear any DIC messages.
- Depress and releaser throttle pedal rapidly 3 times (within a second or so).
- Oil Life will be 99%.
