1997 - 2005 Corvette: Service Bulletin: Revised Ball-Joint Torque Specs
Service Bulletin #: 05-03-08-004
Date: 3/31/05
Subject:  Revised Front and Rear Upper and Lower Ball Joint Stud Nut Tightening Specifications
Model(s): 1997 - 2005 Chevrolet Corvette
This bulletin is being issued to revise the upper and lower ball joint stud nut tightening specifications in the Front Suspension sub-section and the Rear Suspension sub-section of the Service Manual.
Front Suspension
1997-2004 Upper Ball Joint Stud Nut
20 N·m (15 lb ft) + 250 degrees
2005 Upper Ball Joint Stud Nut
30 N·m (22 lb ft) + 225 degrees
1997-2005 Lower Ball Joint Stud Nut
30 N·m (22 lb ft) + 180 degrees
Rear Suspension
30 N·m (22 lb ft) + 195 degrees
