1997 - 2011 Corvette: Service Bulletin: #PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)
Estimated Reading Time: 1 Minutes#PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)
Subject: | Torque Tube Fully Serviceable |
Models: | 2004 - 2009 Cadillac XLR, XLR-V |
1997 - 2011 Chevrolet Corvette, Corvette Z06 | |
2009 - 2011 Chevrolet Corvette ZR1 |
This PI was superseded to update models and model years. Please discard PIP4245.
- Condition/Concern:
Any condition that would require service or perceived replacement of the torque tube.
- Recommendation/Instructions:
The torque tube in the above listed vehicles is fully serviceable. The service and overhaul procedures can be found in "Driveline/Axle" section of SI, then select "Propeller Shaft". Please do not replace the complete torque tube assembly unless absolutely necessary.
