1997 Corvette: Service Bulletin: Erratic Fuel Gauge Readings
Estimated Reading Time: 1 Minutes Source: Chevrolet Dealer Service Bulletin
Number: 73-83-22
SUBJECT: ERRATIC FUEL GAUGE READINGS (REPAIR PINCHED WIRES)
MODELS: 1997 CHEVROLET CORVETTE
CONDITION:
SOME OWNERS MAY COMMENT ON ERRATIC READINGS FROM THE FUEL GAUGE.
CAUSE:
THE SENDER WIRES FROM EITHER TANK MAY BE TRAPPED UNDER THE FUEL OR EVAPORATOR LINES WHERE THE LINES ROUTE BETWEEN THE BODY AND THE FRAME RAIL IN THE REAR.
CORRECTION:
INSPECT THE AREA ABOVE FOR PINCHED WIRES. IF THE WIRES DO NOT MOVE FREELY, THEY MAY BE PINCHED. THE HARNESS IS #1 IN FIGURE 1.
REPAIR THE WIRES AS NECESSARY. MAKE SURE THAT THE WIRES ARE PROPERLY ROUTED, AND MOVE FREELY, TO INSURE THAT THEY WILL NOT BE PINCHED IN THE FUTURE. IT MAY BE NECESSARY TO REMOVE ONE OR BOTH FUEL TANKS FOR ACCESS TO THIS AREA. IF SO, FOLLOW THE PROCEDURES ON PAGE 6-970 IN THE SERVICE MANUAL.
WARRANTY INFORMATION:
FOR VEHICLES REPAIRED UNDER WARRANTY, USE:
LABOR OPERATION NUMBER: N6420 USE PUBLISHED LABOR OPERATION TIME.
FIGURES: 01 ATTACHMENTS: 00
