1997 Corvette: Service Bulletin: Various Driveability Issues (Repair/Secure Wire Harness at PCM)
Subject: VARIOUS DRIVEABILITY CONDITIONS (REPAIR/SECURE WIRE HARNESS AT PCM)
Number: 83-81-24 - (03/03/1998)
Models: 1997 CHEVROLET CORVETTE
Condition:
SOME CUSTOMERS MAY REPORT ONE OR MORE DRIVEABILITY CONDITIONS WHICH MAY OR MAY NOT SET A MALFUNCTION INDICATOR LAMP (MIL) OR A DIAGNOSTIC TROUBLE CODE (DTC).
Cause:
THE SERVICE LOOP OF THE WIRE HARNESS FOR THE PCM MAY BE INCORRECTLY ROUTED. THE HARNESS MAY RUB AT THE TOP FRONT CORNER OF THE PCM (SHOWN ON PAGE 6-942 OF THE SERVICE MANUAL, VOLUME 3). THIS CONDITION WAS CORRECTED IN PRODUCTION IN MAY, 1997 BY ADDING ADDITIONAL CONDUIT AND IMPROVING THE HARNESS ROUTING.
Correction:
REPAIR ANY CHAFFED OR CUT WIRES FOLLOWING THE INSTRUCTIONS IN SECTION 8 OF THE SERVICE MANUAL. ADD ADDITIONAL TAPE OR CONDUIT TO THE WIRE IN THE DAMAGED AREA AND SECURE THE HARNESS TO PREVENT ANY FURTHER DAMAGE.
