1998 - 2001 Corvette Convertible: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)
Estimated Reading Time: 1 Minutes Source: Chevrolet Dealer Service Bulletin
Number: 01-08-67-003
Subject: Squeak From Rear of Convertible Top (Replace Protector Assembly)
Model Year: 1998-2001 Corvette
Condition
Some customers may comment on a squeak coming from the rear of the convertible top.
Cause
This condition may be caused by interference between the fifth bow seal and the tonneau cover rub strip. (Refer to the illustration above).
Correction
- Remove the old seal.
- Remove any two way tape from the body.
- Clean the surface.
- Install a new front top stow compartment lid protector assembly.
Parts Information
Part Number |
Description |
10313384 |
Front Top Stow Compartment Lid Protector Assembly |
Parts are currently available at GMSPO.
Warranty Information
Labor Operation |
Description |
Labor Time |
B3700 |
Applique and/or Protector Stowage Lid Replace |
0.3 hr |
