1998 - 2003 Corvette Convertible: Prevention of Convertible Top From Rubbing Against the Paint Behind the Plastic Strip
Estimated Reading Time: < 1 MinuteIf you raise the rear portion of the canvas top, you will see the strut rods on each side which can be adjusted.
Each rod has a 13mm adjusting nut and a 15mm locking nut. Loosen this locking nut and slightly turn the adjusting nut a little at a time. Each time you turn the nut, raise the top and check for proper clearance. The amount of clearance should be equivalent to the thickness of a credit card.
