1998 Corvette Convertible: Service Bulletin: Tonneau Cover Makes Noise When Going Over Bumps
Estimated Reading Time: 1 Minutes Subject: TONNEAU COVER MAKES NOISE WHEN GOING OVER BUMPS (INSTALL TAPE)
Number: 83-15-06 - (04/22/1998)
Models: 1998 CHEVROLET CORVETTE CONVERTIBLE
Condition:
SOME CUSTOMERS MAY COMMENT THAT THE TONNEAU COVER MAKES NOISE WHEN GOING OVER BUMPS, WITH TOP IN THE UP POSITION.
Cause:
THIS SITUATION MAY BE CAUSED BY THE RUBBER STOP BUMPERS HAVING A STICK/SLIP CONDITION TO THE TONNEAU COVER.
Correction:
1. CLEAN TONNEAU COVER IN THE AREA SHOWN (FIGURE 1) WITH A GENERAL PURPOSE CLEANER.
2. INSTALL A PIECE OF 3M(R) SCOTCH SQUEAK REDUCTION TAPE (P/N 06356), OR EQUIVALENT, TO THE TONNEAU COVER.
