1999 - 2000 Corvette: Service Bulletin: SMU - Deletion of Variable Effort Steering Description
Estimated Reading Time: 1 MinutesSource: Chevrolet Dealer Service Bulletin
Number: 00-02-36-002A
Subject: SMU - Deletion of Variable Effort Steering Description
Model Year: 1999-2000
This bulletin is being revised to clarify that the Variable Effort Steering is not dealer adjustable using a scan tool. Please discard Corporate Bulletin Number 00-02-36-002 (02 -- Steering).
This bulletin is being issued to delete the information below that is found in the Variable Effort Steering Description in the Variable Effort Steering sub-section of the Service Manual.
Please delete:
The scan tool can be used to adjust the amount of steering effort, if the customer requests. The steering assist has (3) settings:
- Factory Calibration
- More Firm
- Less Firm
