1999 - 2001 Corvette: Service Bulletin: Windnoise Around B-Pillar (Add Sealer)
Estimated Reading Time: 1 Minutes Source: Chevrolet Dealer Service Bulletin
Number: 01-08-58-001
Subject: Windnoise Around B-Pillar (Add Sealer)
Model Year: 1999-2001 Corvette Hardtop
Condition
Some owners may comment on windnoise around the B-pillar.
Cause
The windnoise may be caused by a void in the sealer behind the B-pillar weatherstrip retainer.
Correction
Remove the weatherstrip retainer and the B-pillar exterior molding. Seal the void with GM RTV Silicone Rubber Sealant-Black, P/N 12345739 (in Canada, use P/N 10953541).
Parts Information
Part Number |
Description |
12345739 (U.S.) 10953541 (Canada) |
GM RTV Silicone Rubber Sealant-Black |
Warranty Information
Labor Operation |
Description |
Labor Time |
C1520 |
Retainer (RH), Weatherstrip Body Lock Pillar |
0.4 hr |
C1521 |
Retainer (LH), Weatherstrip Body Lock Pillar |
0.4 hr |
