2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative
Estimated Reading Time: < 1 MinuteBulletin No: 03.08.42.012
Subject: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative (Reprogram BCM)
2000-2004 Chevrolet Corvette with Automatic Headlamp Control (RPO T82)
Condition
Some customers may comment that the twilight sentinel/automatic headlamp control delays turning on/turning off or is inoperative.
Correction
A procedure using the Tech 2® has been developed to reprogram the twilight sentinel feature within the BCM.
