2000 Corvette: Service Bulletin: Power Antenna Not Working Properly or is Completely Inoperative
Estimated Reading Time: 2 MinutesNumber: 00-08-44-006A
Subject: Power Antenna Not Working Properly or is Completely Inoperative (Replace Antenna O-Ring Assembly/Cap Nut & Clean Mast)
Model Year: 2000 Chevrolet Corvette, 2000 Pontiac Firebird, 2000 Chevrolet and GMC G-Van
This bulletin is being revised to change the labor time. Please discard Corporate Bulletin Number 00-08-44-006 (Section 8 -- Body & Accessories).
Condition
Some customers may comment on the power antenna doing the following:
- Will not go up all the way
- Will not go down all the way
- Will not move at all
Cause
The O-ring/cap nut material may not be compatible with the lubricant used on the antenna mast. This incompatibility may cause the O-ring/cap nut to enlarge and place a drag on the antenna mast, restricting its movement.
Correction
Inspect the antenna mast and housing for damage (bent mast or housing). If damaged, perform the normal non-warranty repair. Otherwise, if no damage is present, perform the following repair:
- Turn the radio entertainment system to the OFF position.
- Place the ignition key in the OFF position and remove the key from the key switch.
Important
Do not allow the antenna to be activated while the O-ring assembly/cap nut is removed from the antenna. Allowing the antenna to activate with the O-ring assembly/cap nut removed will allow the antenna mast to come completely out of the assembly. - Using an adjustable wrench, loosen and remove the antenna O-ring assembly/cap nut.
- Install the new O-ring assembly/cap nut to the antenna mast, finger tight, then tighten 1/4 additional turn.
- Place the ignition key in the key switch and turn to the run position. Turn ON the radio.
- With the antenna in the full up position, clean the mast with a clean rag.
Parts Information
Model |
Part Number |
Description |
Camaro & Firebird |
12369494 |
O-Ring Assembly/Cap Nut |
Corvette |
88896816 |
G-Van |
88897381 |
