2000 Corvette: Service Bulletin: Tech - Left Headlamp Door Does Not Stay Closed
Estimated Reading Time: 2 Minutes Number: 00-08-42-002
Subject: Tech - Left Headlamp Door Does Not Stay Closed
Model Year: 2000
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number |
Description |
Qty Per Vehicle |
11505463 |
Washer |
3 |
16524060 |
Insulator |
2 |
Parts are expected to be available from GMSPO, 6/15/00.
Warranty Information
Labor Operation |
Description |
Labor Time |
N3231 |
Actuator Assembly, Left Front Headlamp- Replace Note: Also Referred to as "Motor Assembly" |
0.5 hr |
