2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise
Estimated Reading Time: 2 MinutesSubject: Engine Knock or Lifter Noise (Replace O-Ring)
Model and Year:
2001-2002 Chevrolet Camaro
2001-2003 Chevrolet Corvette
2001-2002 Pontiac Firebird
2002-2003 Cadillac Escalade, Escalade EXT
2000-2003 Chevrolet Suburban, Tahoe
2001-2003 Chevrolet Silverado
2002-2003 Chevrolet Avalanche
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Sierra
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U -- RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
Bulletin Number: 02-06-01-038 - (12/02/2002)
Condition
Some customers may comment on an engine tick noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
Cause
The O-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
Correction
Inspect the O-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
Parts Information
Part Number |
Description |
Qty |
12557752 |
Seal-O/Pmp (O-ring) (F and Y Cars) |
1 |
12563963 |
Seal-O/Pmp (O-ring) (C/K Trucks) |
1 |
Warranty Information
Labor Operation |
Description |
Usage |
Labor Time |
J1060 |
Pickup Tube and Screen - Replace |
F Car |
3.7 hrs |
Y Car |
4.3 hrs |
C Truck |
1.3 hrs |
K Truck |
2.1 hrs |
