2001 - 2004 Corvette Z06: Locating Replacement "Fix-A-Flat" for Z06 Tires
Estimated Reading Time: < 1 MinuteYou should be able to get a replacement repair kit (can of "Fix-A-Flat", valve stem remove and a replacement valve stem) at your local Chevrolet dealer. The part number is #9593932.
