2001 Corvette: Service Bulletin: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)
Subject: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)
Number: 02-06-01-021
Models: 2001 Chevrolet Corvette with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL) with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
Condition:
Some owners may comment on a whistle noise coming from either the intake manifold or the throttle body. The noise is most noticeable between 1100 and 2000 RPM.
Cause:
This condition may be the result of airflow through the intake manifold.
Correction:
Replace the intake manifold with the part listed below. Refer to the Intake Manifold Replacement procedure in the Engine Mechanical - 5.7L sub-section of the Service Manual (SI Document ID #642853).
Parts Information:
Part Number
Description
Qty
88894339
Manifold, Intake
1
Warranty Information:
Labor Operation
Description
Labor Time
J0250
Manifold, Intake - Replace
Use Published Labor Time
