2003 Corvette: Service Bulletin: Deck Lid Not Flush With Left Hand Quarter Panel (Install Struts, Replace Right Deck Lid Hinge)
Estimated Reading Time: 1 MinutesSubject: Deck Lid Not Flush With Left Hand Quarter Panel (Install Struts, Replace Right Deck Lid Hinge)
Number: #03-08-66-001 - (01/13/2003)
Models: 2003 Chevrolet Corvette Convertible and Z06
Condition:
Some customers may comment that the deck lid is not flush with the left-hand quarter panel when it is closed.
Cause:
The single strut used on the left hand side of some 2003 models may cause the deck lid to not be flush with the quarter panel.
Correction:
Open the deck lid and inspect the right hinge for the ball stud provision that allows for installation of a strut. If the ball studs are missing, replace the right hinge with P/N 10426104, hinge assembly. Remove the single strut from the left side hinge. Install the struts, P/N 10278149, on the left and the right deck lid hinges. The replacement hinge and struts were used on 2002 models.
Parts Information:
Part Number |
Description |
Qty |
10278149 |
Strut- Rear Compartment Lid |
2 |
10426104 |
Hinge - Rear Compartment Lid RH Side |
1 |
