2003 Corvette: Service Bulletin: Info - Recommended Wheel Nut/Bolt Torque Specifications
Estimated Reading Time: 2 MinutesSubject: Info - Recommended Wheel Nut/Bolt Torque Specifications
Model and Year:
Table 1: 2003 Passenger Cars Table 2: 2003 Light Duty Trucks
Bulletin Number: 02-03-10-008 - (12/17/2002)
This bulletin is being issued to list the recommended wheel nut/bolt torque specifications for passenger cars and light duty trucks for the 2003 model year.
2003 Passenger Cars
Vehicle |
Fasteners |
Bolt Circle Diameter (mm) |
Lugwrench Hex Size |
Service Torque | ||
Number |
Size |
N·m |
lb ft |
J |
5 |
M12 x 1.5 |
100 |
19 mm |
140 |
100 |
B, C, D, G, H, K, N, U Van, W |
5 |
M12 x 1.5 |
115 |
19 mm |
140 |
100 |
Corvette |
5 |
M12 x 1.5 |
120.65 |
19 mm |
140 |
100 |
Pontiac Vibe |
5 |
M12 x 1.5 |
100 |
21 mm |
103 |
76 |
Vehicle and Application |
Fasteners |
Service Torque | ||
Number |
Size |
N·m |
lb ft |
S/T (All) |
5 |
M12 x 1.5 |
120.65 |
19 mm |
140 |
100 |
GMT360/370 (All) |
6 |
M12 x 1.5 |
127 |
19 mm |
140 |
100 |
M/L (All) |
6 |
M14 x 1.5 |
139.7 |
22 mm |
190 |
140 |
G/H10 (All) |
6 |
M14 x 1.5 |
139.7 |
22 mm |
190 |
140 |
G20, 30 (All) |
8 |
M14 x 1.5 |
165.1 |
22 mm |
190 |
140 |
C/K 15 (All Except 1500HD) |
6 |
M14 x 1.5 |
139.7 |
22 mm |
190 |
140 |
C/K 1500HD, 25, 35 & 36 (Including Dual Wheels) |
8 |
M14 x 1.5 |
165.1 |
22 mm |
190 |
140 |
HUMMER H1 |
8 |
9/16-18 |
165.1 |
7/8 in |
190 |
140 |
HUMMER H2 |
8 |
M14 x 1.5 |
165.1 |
22 mm |
190 |
140 |
Tracker (All) |
5 |
M12 x 1.25 |
139.7 |
19 mm |
95 |
69 |
* -- Dual wheel trucks - torque specifications apply to front and rear wheels. |
