2005 - 2006 Corvette: Camapaign: Service Active Handling
Vehicle Make / Model:     Model Year(s):
     CHEVROLET / CORVETTE     2005-2006
Manufacturer: GENERAL MOTORS CORP. Mfr’s Report Date: APR 26, 2010
NHTSA CAMPAIGN ID Number: 10V172000 NHTSA Action Number: EA09002
Component: STEERING:COLUMN
Potential Number of Units Affected: 40028
Summary:
 GM IS RECALLING CERTAIN MODEL YEAR 2005 AND 2006 CHEVROLET CORVETTE PASSENGER CARS MANUFACTURED BETWEEN MARCH 2004 AND JANUARY 2006 EQUIPPED WITH A TILT AND TELESCOPING STEERING COLUMN (RPO N37). IN RARE CASES, REPEATED MOVEMENT OF THE STEERING COLUMN MAY CAUSE A SIGNAL INTERRUPTION WITHIN THE COLUMN. IF THIS OCCURS, THE MESSAGE, "SERVICE ACTIVE HANDLING SYSTEM" WILL APPEAR IN THE DRIVER INFORMATION CENTER, AND ONE OR MORE OF THE BRAKES MAY APPLY, POSSIBLY CAUSING THE VEHICLE TO PULL TO THE RIGHT OR LEFT.
Consequence:
 IF THE DRIVER DOES NOT RESPOND TO THE CHANGE IN VEHICLE MOVEMENT, A CRASH COULD OCCUR.
Remedy:
 GM WILL NOTIFY OWNERS AND DEALERS WILL REPAIR THE VEHICLES FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT APRIL 30, 2010. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463 OR AT THE OWNER CENTER AT WWW.GMOWNERCENTER.COM.
Notes:
 GM’S RECALL CAMPAIGN NUMBER IS N100118. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
  1. only did this 3 times when I am driving over 80 mph or if I am driving over a speed bump at a very slow speed 2-3 mph. The dic panel will display reduce speed and the active handling light is displayed at the same time. I will have to pull over and turn the car off and restart it to resume speed.
