2005 - 2006 Corvette: Engine Oil Life Monitor Reset
Estimated Reading Time: 1 Minutes2001 - 06 Corvette
1. Turn the ignition to ON, with the engine off.
2. Press the TRIP button so the OIL LIFE percentage is displayed.
3. Press RESET and hold for two seconds. OIL LIFE REMAIN 100% will appear.
