2005 - 2006 Corvette: Recall: Power Steering Hose Fracture
Estimated Reading Time: 2 MinutesRecall #: 05086
Date: October 6, 2005
Subject: Power Steering Hose Fracture
Model(s):
2005 Chevrolet Corvette VIN#s: 55132486 - 55135514
2006 Chevrolet CorvetteVIN#s: 65100198 - 65100359
Condition
Some vehicles were shipped with a high pressure power steering hose manufactured with an incorrect compound making the hose susceptible to high pressure failure when exposed to the elevated hydraulic fluid temperatures and pressures that can occur during simultaneous braking and steering inputs. When sufficient fluid is lost, power assist for steering is no longer available and vehicle directional control will depend on manual steering efforts.
In addition, braking assist will be limited to the reserve power assist system if the vehicle is equipped with the Hydroboost braking system. The braking systems on vehicles without Hydroboost are unaffected by this condition. There also is a possibility that leaking power steering fluid could flow onto the surface of exhaust system components where surface temperatures could exceed the ignition temperature of the fluid and could result in a fire without prior warning.
Correction
To correct this condition, dealers are to inspect power steering hose assemblies for specific date codes and replace suspect hoses with new parts currently released for production. These repairs will be made at no charge to customers.
