2005 - 2006 Corvette: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC)
Service Bulletin #:  06-02-35-002
Date: January 2006
Subject:  Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
Model(s):
2004 - 2006 Cadillac XLR
2005 - 2006 Chevrolet Corvette
with Steering Wheel -- Tilt, Telescoping (RPO N37)
  • Attached Files
  • 06-02-35-002.pdf (106.85 KB) 1419
