2005 - 2006 Corvette: Service Bulletin: Information on Visual Brake Rotor Surface Cracking
Service Bulletin #:  05-05-23-007
Date: August 2005
Subject:  Information on Visual Brake Rotor Surface Cracking
Model(s):
2005 - 2006 Chevrolet Corvette with Heavy Duty Brakes (RPO J55)
  • Attached Files
  • 05-05-23-007.pdf (24.54 KB) 568
