2005 - 2006 Corvette: Service Bulletin: Release of DEXRON VI Automatic Transmission Fluid (ATF)
Estimated Reading Time: 2 MinutesService Bulletin #: 04-07-30-037A
Date: August 19, 2005
Subject: Release of DEXRON VI Automatic Transmission Fluid (ATF)
Model(s): 2005-2006
This bulletin is being revised to announce the use of DEXRON®-VI with the start of the 2006 model year production.
DEXRON®-VI ATF
General Motors Powertrain has recently upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
Only 2005 and prior models that currently use DEXRON®-III may use DEXRON®-VI as a replacement.
All 2006 and future models that use DEXRON®-VI are to be serviced with DEXRON®-VI fluid only.
DEXRON®-VI is an improvement over DEXRON®-III in the following area:
DEXRON®-VI
Extended Factory Fill For Life
160,000 km (100,000 mi) For Cars and Light Duty Trucks*
80,000 km (50,000 mi) (Severe Use) For Cars and Light Duty Trucks*
Clutch Friction Stability
Improved 100%
Clutch Durability Due To Fluid
Improved 120%
Oil Film Thickness
Increased 20%
Fluid Oxidation
mproved 100%
Foam / Aeration
Improved 150%
Shear Stability
Improved 200%
88861003 (US)
DEXRON®-VI Auto Trans Fluid (1 Quart Bottle)
88861045 (US)
DEXRON®-VI Auto Trans Fluid (1 Gallon Bottle)
88861004 (CANADA)
DEXRON®-VI Auto Trans Fluid (1 Liter Bottle)
88861043 (CANADA)
DEXRON®-VI Auto Trans Fluid (4 Liter Bottle)
