2005 - 2006 Corvette: Service Bulletin: Wipers Will Not Park
Subject: Wipers Will Not Park
Number: #PIC3761
Models: 2004-2006 Cadillac XLR
               2005-2006 Chevrolet Corvette
Condition/Concern:
Some customers may state that the wipers will not park after using the wipers in any position. The customer may also notice that when using the mist button, the wipers will stop when the switch is released and mist function will not continue to wipe windshield and park.
Recommendation/Instructions:
Check the wiper on/off relay (relay #45) in the Underhood Buss Electrical Center (UBEC) and make sure that the relay is properly secured into the socket of the UBEC. If the relay is secured, try a good known relay from a good known vehicle and replace as needed.
