2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71
Estimated Reading Time: 1 MinutesDate: September 28, 2006
Subject: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71
Models: 2005-2007 Cadillac XLR and XLR-V
2005-2007 Chevrolet Corvette
Condition/Concern:
Intermittent Service Stability Message on the DIC with ONLY DTC C0561 Symptom 71 set in history or current. This is the result of a software concern within the EBCM
Recommendation/Instructions:
Revised EBCM software is under development. Replacement of the EBCM or BCM will not correct this condition. Revised software should be available in November 2006.
