2005 - 2008: Service Bulletin: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC
Estimated Reading Time: 2 MinutesSubject: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC, DTC C0710 Steering Wheel Position Sensor (SWPS) Signal Set (Install Clip in SWPS Connector) #06-02-35-002B - (10/19/2007)
Models:
2004-2008 Cadillac XLR
2005-2008 Chevrolet Corvette
with Steering Wheel - Tilt, Telescoping (RPO N37 or N38)
Condition
Some customers may comment on a Stabilitrak® or Active Handling System light being illuminated. Also, this warning light will be accompanied by a SERVICE STABILITRAK or SERVICE ACTIVE HNDLG message on the DIC.
Diagnosis with a scan tool may reveal a DTC C0710.
Cause
The most likely cause of a DTC C0710 on a vehicle equipped with telescoping/tilt steering wheel is high resistance in SWPS connector C202. Fretting terminal corrosion may be present in the SWPS connector due to the telescoping motion of the steering column. When the steering column is telescoped in and out, the female terminals within the SWPS connector may move on the male terminals of the SWPS. This movement between the terminals may cause a high resistance condition in the SWPS connector.
Correction
Remove the driver’s side closeout (insulator) panel.
Locate the SWPS connector that connects to the steering angle sensor, located on the lower center of the steering column.
Install the clip (1), P/N 19179794, into the connector. This clip will act as a terminal positive assurance (TPA) and prevent any movement of the terminals.
© Copyright General Motors Corporation. All Rights Reserve
I would have to agree with joe because this is the second time my c6 has been at the dealership so Corvette should stand beside every Corvette owners and get this serious issue resolved.
Seems as though this should be a more serious RECALL than a passive Service Bulletin. On another note, my 2006 C6 airbag light kept coming on. I checked with the OnStar techs and they saw no problem. Then I got an email warning. The fix? I replaced the OEM battery.
