2005 Corvette: GM TechLink: Gasoline Engine Oil Requirements
Estimated Reading Time: 1 Minutes2005 GM gasoline engines require the use of an engine oil that has the American Petroleum Institute (API) Starburst and states that it meets GM Standard GM6094M (non-synthetic) or GM4718M (synthetic). Failure to use the recommended engine oil can result in engine damage not covered by warranty.
In the March 2005 issue, TechLink published a list of engine oil brands that meet GM Standard GM6094M and GM4718M. This list has be updated through April 12, 2005.
TIP: This list will be updated in the future as required. Download the latest PDF document on the left.
