2005 Corvette: Service Bulletin: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)
Estimated Reading Time: 1 MinutesService Bulletin #: 05-08-68-001
Date: n/a
Subject: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)
Model(s): 2005 Chevrolet Corvette with Manual Transmission (RPO MN6)
Condition Some customers may comment of a Malfunction Indicator Lamp .
Some customers may comment that the cruise control is inoperative.
A scan tool may reveal a DTC P0833.
Cause The Clutch Release Switch may be misadjusted.
Correction Readjust the clutch release switch
