2006 - 2007 Corvette Z06: Customer Satisfaction Campaign 06092: Brake Pad Inspection
Date: October 11, 2006
Subject: Customer Satisfaction Campaign 06092 - Brake Pad Inspection
Models: 2006-2007 Chevrolet Corvette Z06
Condition
The owner manual for 2006 and 2007 Chevrolet Corvette vehicles indicates that all vehicles are equipped with disc brake pads that have a built-in wear indicator that makes a high-pitched sound when the brake pads are worn and require replacement. The disc brake pads on Corvette Z06 vehicles do not have this audible warning indicator and should be inspected to determine brake wear. Costly brake repairs may result if the pads are not replaced in time.
Correction
An owner manual supplement will be sent to owners of record that describes the proper way to inspect for brake wear. Dealers are to place a copy of the supplement in the owner manual of vehicles in their inventory.
All registered owners will receive this mailing, instructing about brake pad inspection.
