2006 - 2014 Corvette: Service Bulletin: #PIP5429: 2-3 Upshift Slip or Flare - (Oct 10, 2016)
Estimated Reading Time: 2 Minutes#PIP5429: 2-3 Upshift Slip or Flare - (Oct 10, 2016)
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
ATS |
2013 |
2015 |
All |
All |
All |
6L45 |
Cadillac |
CTS-V |
2010 |
2015 |
All |
All |
All |
6L90 |
Cadillac |
SRX |
2007 |
2009 |
All |
All |
All |
6L50 |
Cadillac |
XLR, XLR-V |
2006 |
2009 |
All |
All |
All |
6L80 |
Chevrolet |
Caprice PPV |
2011 |
2016 |
All |
All |
All |
6L45, 6L80 |
Chevrolet |
Colorado |
2015 |
2017 |
All |
All |
All |
6L50 |
Chevrolet |
Corvette |
2006 |
2014 |
All |
All |
All |
6L80 |
Chevrolet |
Silverado |
2007 |
2017 |
All |
All |
All |
6L80, 6L90 |
Chevrolet |
SS |
2014 |
2017 |
All |
All |
All |
6L80 |
GMC |
Canyon |
2013 |
2017 |
All |
All |
All |
6L50 |
GMC |
Sierra, Sierra Denali, |
2007 |
2017 |
All |
All |
All |
6L80, 6L90 |
Hummer |
H2, H2 SUT |
2008 |
2011 |
All |
All |
All |
6L80 |
Involved Region or Country |
NORTH AMERICA and N.A. EXPORT REGIONS |
Additional RPO/s: |
N/A |
Condition |
Some customers may comment on a 2-3 upshift slip or flare. |
Cause |
This condition is a NORMAL characteristic of the transmission, it will not cause durability concerns and no repair attempts should be made. |
Service Procedure:
At this time this flare condition has been recognized in two different driving conditions:
- During the first 2-3 upshift after the vehicle has been sitting, engine off for several hours. This condition may be caused by air that is trapped in the 3-5-R clutch assembly.
When the first 2-3 upshift is made this trapped air is purged and the following 2-3 shifts will be normal with no flare.
When diagnosing this condition a garage shift into reverse before drive will purge this air and prevent the 2-3 flare from occurring. This condition is a NORMAL characteristic of the transmission, it will not cause durability concerns and no repair attempts should be made.
- When transmission ATF temperature is at or below 85 degrees F (30 degrees C). This 2-3 upshift flare can occur until the ATF temperature warms. If the 2-3 flare is determined to be ATF temperature sensitive use a Tech 2 to make note of the throttle position when the flare occurs. Drive the vehicle to get ATF temperature to at least 104 degrees F (40 degrees C) and then make several 2-3 shifts at the throttle position determined to be the most sensitive to the 2-3 flare. This will allow the transmission adapts to tailor the shifts and may help to eliminate the cold 2-3 flare. This condition is a NORMAL characteristic of the transmission, it will not cause durability concerns and no repair attempts should be made.
Notice: A revised TCM calibration has been released and is available on TIS2WEB to improve this concern in 2007 vehicles equipped with the 6L90 RPO MYD automatic transmission
