2006 Corvette: GM TechLink: Brake Pads
Brake Pads
For 2006, a new brake pad is introduced on the Z51 Corvettes for reduced operating noise. It is quieter than the pad used in 2005.
TIP: Use European specification brake pads for autocross competition. However, operating noise will be noticed with these pads.
Source:  GM Techlink, Sept, 2005
