2006 Corvette: Service Bulletin: 4L60-E, 4L65-E Automatic Transmission fluid Leak from Oil Pump or Bell Housing Area
Subject:  4L60-E, 4L65-E Automatic Transmission Fluid Leak from Oil Pump or Bell Housing Area (Remove Small Burrs on Torque Converter Hub, Pump Drive Slots and Replace Torque Converter Hub-to-Oil Pump Seal Assembly (243)
Models:  2006 Chevrolet Corvette with 4L60-E or 4L65-E Automatic Transmission (RPOs M30 or M32)
Bulletin No:  06-07-30-016
Date:  July, 2006
Download PDF attachment below.
  • Attached Files
  • 060730016.pdf (93.06 KB) 680
