2006 Corvette: Service Bulletin: Cold Tire Characteristics of GM Original Equipment Tires
Attached below is a one page PDF document detailing the cold tire characteristics that may be seen on all GM original equipment tires.
  • Attached Files
  • 03-03-10-007a.pdf (34.42 KB) 760
