2007 - 2013 Corvette: Service Bulletin: 15682 Primary Tank Module Flange Fuel and Vapor Leaks - Revised
Special Coverage Adjustment
Reference Number: N150682
Release Date: August 2016
GWM Number: 2015682
Revision: 01
Revision Description: This bulletin is being revised to accurately depict the origin on the flange in which fuel and vapor leaks have been confirmed. Please discard all previous copies of bulletin 15682.
Condition: Some 2007 to 2009 model year Cadillac XLR and 2007 to 2013 model year Chevrolet Corvette vehicles may have a condition where a fuel odor is detected, fuel droplets appear below the left-hand fuel tank with fuel gauge level above 1/2, or a malfunction indicator lamp illuminates due to a leak path in the left-hand fuel pump module flange.
Service Bulletin attached below:
  • Attached Files
  • 15682_02_bulletin.pdf (336.9 KB) 2920
