2007 Corvette: Service Bulletin: Information Regarding Automatic Transmission Shift Lock Control Function
Service Bulletin #:  03-07-30-043a
Date: May 2005
Subject:  Information Regarding Automatic Transmission Shift Lock Control Function
Model(s):
2007 and Prior Passenger Cars and Trucks (Including Saturn)
2007 and Prior HUMMER H2, H3
2005 - 2007 Saab 9-7X
with Automatic Transmission
This bulletin is being revised to add models and model years.  Please discard Corporate Bulletin Number 03-07-30-043 (Section 07 -- Transmission/Transaxle)
  • Attached Files
  • 03-07-30-043a.pdf (41.55 KB) 660
