2014 - 2016 Corvette: Service Bulletin: #16-NA-170: Brake Pulsation and/or Vibration During Brake Apply
Estimated Reading Time: 1 Minutes#16-NA-170: Brake Pulsation and/or Vibration During Brake Apply - (July 20, 2016)
Subject : | Brake Pulsation and/or Vibration During Brake Apply |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Corvette |
2014 |
2016 |
Involved Region or Country |
North America and NA Export vehicles. |
Additional Options (RPO) |
BRAKE SYSTEM-HEAVY DUTY (RPO J55) |
Condition |
Some customers may comment on a pulsation and/or vibration when they apply the brakes. Customer may also comment they hear a rattle noise from the wheel area. The noise may go away when the brakes are lightly applied. |
Cause |
This condition may be due to excessive lateral runout (LRO) or interation between the inner top hat section to the rotor ring. |
- Correction
Check the lateral runout:
- For front rotors and vehicles built prior to May 31, 2016, replace old two piece design (2) with new one piece design (1).
- For rear rotors and vehicles built prior to July 23, 2015, replace old two piece design (2) with new one piece design (1).
Important: The rotors MUST be replaced as a pair due to a design change.
Note: DO NOT replace all brake rotors unless you find the lateral runout out of spec for both the front and rear corners.
- Service Procedure
Refer to Brake Rotor Assembled Lateral Runout Correction and Front and Rear Brake Rotor Replacement-Both Sides in SI.
- Parts Information
Description
Part Number
Qty
ROTOR ASM-FRT BRK
23242229
2
ROTOR-RR BRK
23322785
2
Has been doing this almost since I purchased it new in aug 2016. The shimmy or shake is so bad I almost lost it a few times
