2014 - 2017 Corvette: Service Bulletin: #PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition
#PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition - (Apr 27, 2017)
Subject Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CTS-V
2016-2017
All
All
6.2L LT4
All
Cadillac
Escalade
2015-2017
All
All
6.2L L86
All
Chevrolet
Camaro
2016-2017
All
All
6.2L LT1 LT4
All
Chevrolet
All
All
6.2L LT1 LT4
All
Chevrolet
Silverado 1500
2014-2017
All
All
4.3L LV3 5.3L L83 6.2L L86
All
Chevrolet
Suburban
2015-2017
All
All
5.3L L83
All
Chevrolet
Tahoe
2015-2017
All
All
5.3L L83
All
GMC
Sierra 1500
2015-2017
All
All
All
GMC
Yukon Models
2015-2017
All
All
5.3L L83 6.2L L86
All
Supersession Statement
This PI was superseded to update Repair information and Model Years. Please discard PIP5234B.
Condition/Concern
The dealer may encounter a concern where SI diagnostics indicates a fuel injector may need to be removed for a repair or replaced.
This could be due to a fuel odor and/or extended cranking condition.
Recommendation/Instructions
  1. Install Dye (p/n 88861206) into the fuel system via the filler neck
  2. Start Engine and let idle for 15 minutes
  3. Remove intake manifold
  4. Inspect for any leaks.
    Note: **** Tightening the nuts is not an approved procedure *****
  5. After installing the seals and new pipes, start the engine let it idle for 5 min and confirm no leak is evident. Performing a post-install leak check has proven to be beneficial so customers do not return with another leak.
  6.   If required, replace the engine insulator if absorbed with fuel or emits a fuel odor.
If you cannot conclude if the leak is coming from one of the fuel feed pipes, start the engine and let idle for 5 minutes looking for source of leak. Refer to SI for further diagnostics.
If this concern is encountered use the O-ring seal listed below.
If an injector is being replaced be sure all the injectors are installed with new seals. (That includes the new injector)
The following Fuel injector PN’s require a new O ring before installation.
Important: It is required to replace the engine fuel feed intermediate pipes during any service repairs that required one or more of the pipes to be loosened or removed.
Important: If any damage occurred due to leaking fuel, be sure to replace as necessary. (i.e. Fuel Pump Insulator)
LV1-LV3-L83-L86-LT1 Seal Kit = 12668553 should be used for the following injector kits:
LV1-LV3-L83 Service Injector:
12656932 (Nominal Flow)
LT1/L86 Service Injectors:
12656931 – Nominal Flow
12660002 – Low Flow
12660003 – High Flow
LT4 Seal Kit = 12668554 should be used for the following injector kits:
LT4 Service Injectors:
12661029 – Nominal Flow
12661030 – Low Flow
12661031 – High Flow
Warranty Information
The correction for this concern may be one of several repairs described above.  For vehicles repaired under warranty, please use the appropriate warranty labor operation based on the actual cause and repair
