2014 - 2018 Corvette: Service Bulletin: #PIP5179D: Extended Crank Cold With DI (Direct Injected) Engines - (Mar 27, 2018)
Subject Extended Crank Cold With DI (Direct Injected) Engines
Models 2016–2018 Chevrolet Camaro
2016–2018 Cadillac CTS-V
2015-2018 Cadillac Escalade
2014 - 2018 Chevrolet Corvette
2014-2018 Chevrolet Silverado 1500 Suburban, Tahoe
2014-2018 GMC Sierra 1500 Yukon
with engines 4.3L, 5.3L, 6.2L RPO’s LV3, L83, L86, LT1, LT4
This PI was superseded to update Model Years. Please discard PIP5179B.
Condition/Concern
DI (Direct Injected) Engines with concerns of extended or long crank time during cold ambient airtemps
Recommendation/Instructions
Direct Injection engines may have slightly longer cold crank times than that of port fuel engines.
Direct Injection systems run at higher pressures, and the mechanical pump on the engine must buildup the required pressure before the first injection event occurs.
The below are typical Direct Injection engine crank times on GASOLINE
Start up Coolant Temperature Crank Time
Above 10° C up to 1.5 sec
Between 10°c (50F) and (- 10°c 14F) up to 2.5 sec
Between (-10°c 14F) and (-20°c -4F) up to 3.5 sec
Between (-20°c -4F) and (-25°c -13F) up to 5 sec
Between (-25°c -13F) and (-30°c -22F) up to 7 sec
Below -30 deg. C -22F, the recommendation is to perform an assisted start (such as use of a blockheater).
Note: For ETHANOL fuel see #PIP5174: Extended Engine Crank Times When Using E85
